Mental Ray Rendering
BEKA
hi Beadin
did you use exposure control?...it turned out it lacks contrast. If yes, you can try removing the exposure control.If it turns out dark, as it would be, you can adjust the decay for your photons to around 1.5-1.2. Post an update and tell us if it worked...
You could try adding other lights to make the lighting more interesting, I think the way it is now it's flattening your scene. Also, is the rug floating? And I see that you're not using depth of field but somehow you have it out of focus...
Props to the scaled-down Max trees as potted plants, I'm doing a render right now with the same thing :)
Better lighting, still blurry. Are you Photoshop blurring it to take out the pixellation from have low samples per pixel? (Or in that version of mr, if you set low samples per pixel do you get a blurry image?) Try setting it to min 1, max 16.
Here is my updated Rendered Image,
with samples per pixel: min=1, max=16
My question is why my Image is blurry again.
And what should I do to have sharper Image ?
Thank you very much.
