extruding lines
Alpenshiva
Hello max-users!
When I draw a line and use the "extrude" modifier, the line is beeing extruded along its Z-axis. Now the question: Is it possible to rotate the Z-axis so that the extrusion follows the new Z-axis of the line and results in a rectangle that is somehow skew. (P.S.: I dont´t want to use the skew modifier afterwards)
Thank you for your help!!!
Hello Michiel, this is what I was thinking of. Unfortunately it does not work.
I have attached a file with a rectangle that has the original pivot. The square has a rotated pivot, but both extrusions are along the same axis.
Could you please check my file?
