jvlive Posted August 1, 2005 Share Posted August 1, 2005 this may be a noob question.... is there any way in max where you could lock the proportion of an object so that when you change 1 dimension the others change accordingly? like for example, you have a box with L=10, W=3, H=2. then you want to change L to 16, but you want to lock its proportion to the W, but not H. I know this is easy with scaling(scale transform), but what i want is when i click that object i wd be able to see its correct present dimension. And isnt it nice to be able to just input a dimension & the object will change accordingly while keeping its proportion? Link to comment Share on other sites More sharing options...
Poco Posted August 1, 2005 Share Posted August 1, 2005 Hi jvlive, Have you tried the "wire parameters" under the animation -> wire parameters -> Parameter wire dialog? That tool lets you connect certain parameters too eachother. There is probably an easier way but thats the way I do it. Greets Link to comment Share on other sites More sharing options...
jvlive Posted August 2, 2005 Author Share Posted August 2, 2005 Thanks, Poco! Try that later..... Link to comment Share on other sites More sharing options...
