Crazy Homeless Guy Posted August 1, 2005 Share Posted August 1, 2005 I am trying to set up tree planes to always look at an animated camera. I have done this in Lightwave before, but not in Max. I create a plane. Then go to... Animate... Constraints... LookAt Constraint. The plane looks at the camera, without a problem, but i can not keep it from tilting back or sideways when the camera moves. I have tried different settings, but nothing seems to keep it from tilting. Any ideas...? . Link to comment Share on other sites More sharing options...
Ricardo Eloy Posted August 1, 2005 Share Posted August 1, 2005 There's an option on the Motion tab called Keep Initial Offset. Try that. ;-) Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted August 1, 2005 Author Share Posted August 1, 2005 Rick Eloy said: There's an option on the Motion tab called Keep Initial Offset. Try that. ;-) hmmm.. i couldn't get that to work. it 'squared up' the plane, but it still tilts when i move the camera up in the air. attached is my base file if you or nayone else can look at it. it is version 7.5. Link to comment Share on other sites More sharing options...
MegaPixel Posted August 2, 2005 Share Posted August 2, 2005 I know most Architectural Visualizers steer clear of Particle Systems, but I think that using "Facing" Particle type does the exact thing you are looking for. Facing particles always turn to face perpandicular to the camera. Perhaps creating a particle system with a count of 1 for one type of Tree and then duplicate it however many times you need? Just thoughts - Mega Link to comment Share on other sites More sharing options...
pipjor Posted August 2, 2005 Share Posted August 2, 2005 i had the same problem and could not figure it out. what i did get to work was clone one tree copy at a time and it worked. BTW Particle Flow is pretty fun if you ever have time to play around with it. Link to comment Share on other sites More sharing options...
Ricardo Eloy Posted August 2, 2005 Share Posted August 2, 2005 I got it to work, I think. Send me your e-mail address and I'll send you the file. Link to comment Share on other sites More sharing options...
