dmedraft Posted August 1, 2005 Share Posted August 1, 2005 I'm considering purchasing viz. I have never used auto cad. I have been rendering in C4D and another architecture specific program for 5 years. Is viz a stand alone program or will I need autocad? Can I import models for rendering? What can I expect the learning curve to be? Any advice from the pros? Is there another program that would be a better choice? Thanks, Dean Link to comment Share on other sites More sharing options...
Ray Posted August 1, 2005 Share Posted August 1, 2005 Yes, Viz is a standalone program. You do not need autocad to use it. However, it does have a file link manager in which you can have your 3D Autocad model interactively linked with viz. You can import other formats including .dwg, .3ds and many others (I'm sure you can find a complete list at the Autodesk website). Some people swear by modeling in Autocad and bringing it into Viz, and others say that modeling in Viz is the only way to go. Just depends on your personal preference. As for the learning curve coming from C4D, I'm sure some of the others around here can help you with that. Link to comment Share on other sites More sharing options...
mbr Posted August 2, 2005 Share Posted August 2, 2005 I am curiuos why you'd want to switch? C4D seems to be growing in popularity and all the rendering plugins are making versions for it now. I'd seriously think about it. Link to comment Share on other sites More sharing options...
coastalhomedesigns Posted August 16, 2005 Share Posted August 16, 2005 Dean The work you do is SP will import into VIZ. I go from SP to Viz with only a few item needing to be redone. Once you get to modeling in VIZ you will find it much beter than tring to use the SP cross road. Thanks Charles Kirkland If you have any questions please contact me. Link to comment Share on other sites More sharing options...
