salf Posted August 3, 2005 Share Posted August 3, 2005 The foloowing problem with hatch, happens so far with the GRAVEL and AR-CONC type of hatch. They doesnt display correctly, if apply any of this hatches, they look horrible, not like they suppose to be, for instance, in the gravel hatch, wich should be a bucnh or rounded polygons, are just straight lines in diferent directions. The problem its just with a file im working on, older files or projects, work ok with this hatches, if i try to create a new file, and copy and paste all the drawings, and apply the hatch again, the problem is somehow solved, the hatch will look better, but still doesnt quite looks like it supossed to. Im gonna try to put a screenshot. Link to comment Share on other sites More sharing options...
salf Posted August 3, 2005 Author Share Posted August 3, 2005 ...also.....does anyone know how to "add" a custom hatch pattern ? I mean, i downloaded some hatch patterns form internet, but i dont know how to use them. Link to comment Share on other sites More sharing options...
bigroo Posted August 4, 2005 Share Posted August 4, 2005 Im gonna try to put a screenshot. Try to post some caps of your problem if you haven't yet solved it. Link to comment Share on other sites More sharing options...
Onslaught Posted August 4, 2005 Share Posted August 4, 2005 ...also.....does anyone know how to "add" a custom hatch pattern ? I mean, i downloaded some hatch patterns form internet, but i dont know how to use them. Make sure you put those .pat files in your autocad support folder so that autocad can find it. Then just run your hatch command and go to 'CUSTOM' and it should show up. Link to comment Share on other sites More sharing options...
salf Posted August 5, 2005 Author Share Posted August 5, 2005 thanks guys, i found the solution for both issues: - The hatch problem im talking about its on the autodesk common problems database : http://usa.autodesk.com/adsk/servlet/ps/item?id=2880908&linkID=2475323&siteID=123112 - And fo rthe custom hatch, i did what onslaught said. Link to comment Share on other sites More sharing options...
ishpalsingh Posted August 5, 2005 Share Posted August 5, 2005 its good that u have found the solution for ur problem but could u post the link from where hav u downloaded the hatch patters i need hatch patterns for veneers Link to comment Share on other sites More sharing options...
bigroo Posted August 6, 2005 Share Posted August 6, 2005 could u post the link from where hav u downloaded the hatch patters Would you believe, http://www.hatchpatterns.com/ Link to comment Share on other sites More sharing options...
