oluv Posted August 3, 2005 Share Posted August 3, 2005 when i import or create my model in meter system units i always get an annoying viewport clip. everything in front of the view up to 1 meter is clipped away, i cannot walk around the model because the walls are fading away as soon as i approach. i can turn viewport clip on or off. it doesn't change anything. the only way is to create a camera and set the front clipping to 0 meters manually, but as soon as i turn to perspective view the clip is there again. it doesn't occur with centimeters, because the clip seems to be 1 cm then. but 1 meter is too much. how can i deal with this? most of my models are in meters, and i don't want to screw up the units, because i need them right for radiosity. thanks for all your help! o. Link to comment Share on other sites More sharing options...
abicalho Posted August 3, 2005 Share Posted August 3, 2005 Right-Click the Viewport label and choose Viewport Clipping. You can now adjust it for the perspective view. My suggestion is to not use System Units = Meters, but to use System Units = Inches and then use Display Units = meters. The end result will be the same. Link to comment Share on other sites More sharing options...
Ricardo Eloy Posted August 3, 2005 Share Posted August 3, 2005 I have always used system units set as 1 unit = 0,025 meters. It's like saying 1 inch, just in meters. Interesting enough, if I set it to 1 inch, I get different sizes... Link to comment Share on other sites More sharing options...
oluv Posted August 3, 2005 Author Share Posted August 3, 2005 Right-Click the Viewport label and choose Viewport Clipping. You can now adjust it for the perspective view. unfortunately this doesn't have any effect. the clip remains the same regardless of viewport clipping on or off. My suggestion is to not use System Units = Meters, but to use System Units = Inches and then use Display Units = meters. The end result will be the same. so i think i don't understand max's idea behind system units and display units. i thought system units are the real-world units. if i have a model in centimeters, i should import it with the right system units... if my model is a dwg with let's say 1 unit = 1 centimeter, then i import this into max with 1 unit = 1 inch, and i export the model again, what will my final model-size be? Link to comment Share on other sites More sharing options...
abicalho Posted August 3, 2005 Share Posted August 3, 2005 After you choose Viewport Clipping, adjust those two arrows. Your clipping will then be "fixed". Link to comment Share on other sites More sharing options...
oluv Posted August 3, 2005 Author Share Posted August 3, 2005 After you choose Viewport Clipping, adjust those two arrows. Your clipping will then be "fixed". yeah i can slide both of them but i can only increase the front clip i didn't manage to cancel the front clip. i can slide the arrow to the very bottom, without any change. maybe i should really start to use other units instead. still it is quite annoying. Link to comment Share on other sites More sharing options...
