pygoh Posted August 3, 2005 Share Posted August 3, 2005 Hi, I'm using a very wide angle lens (115deg) in one of my view and things at the ends of the image are quite distorted. Does anyone know of a script or method of doing a wide angle view without the distortion? Thanks Link to comment Share on other sites More sharing options...
MegaPixel Posted August 4, 2005 Share Posted August 4, 2005 I've heard of one trick for doing this which involves rendering a much wider area then you need, then cropping in on your subject afterwards which removes the distorted edges to a degree. Zooming in from far off distances helps a little also. Link to comment Share on other sites More sharing options...
abicalho Posted August 4, 2005 Share Posted August 4, 2005 Increase the width of your camera without increasing the height - a true wide angle photo is not 4x3 in aspect ratio. You can then keep your camera at the usual 20-35mm and the "wide" format will take care of widening the camera area. Hope it helps, Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted August 4, 2005 Share Posted August 4, 2005 another solution proposed by Chris Mac a couple of years ago. it involves mimicking the barrell lens distortion that happens in a real life situation when using a wide angle lens. It won't correct all of your problems, but it might help. His pot is the fourth one down. http://www.cgarchitect.com/vb/showthread.php?t=1425&highlight=spherize+lens . Link to comment Share on other sites More sharing options...
