Missing pulldowns in ADT 2006!!
archkre
I has been a long time since i did this but i think it is the acad.mnu file located in the support folder. I think all the pull down menus are *.mnu and the icons are *.mnc and both need to be loaded.
And as you are customizing i can only guess that you know the command is "menuload"
Hope that helps...
  • 2 weeks later...
Loading "mnu" file still works as AutoCAD converts them into in cui files. A cui file is an xml package containing menu, pgp files etc. I still program mnu files with a ascii editor and load them into AutoCAD using "menuload" rather than use the "customize" option to edit menus etc.
Also Ctrl 0 will clear the AutoCAD screen of all menus. Ctrl 0 will toggle it back.
Cheers Kerry
