chow choppe Posted August 9, 2005 Share Posted August 9, 2005 hi all... can someone tell me that how can i export a part of a movie (in Adobe Premiere)as a quick time file. i mean i set my time duration to six minutes in the beginning but i just need to export first 20 seconds as a quicktime movie using the file....export ..command . I have limited the render area by dragging the cursors in the top of the timeline...but still when i export these 20 seconds it exports the complete movie.... i have my images within this 20 seconds but the audio file i have kept is around 3 minutes...is this is what is causing the problem? That means can't export a part of movie... please help Link to comment Share on other sites More sharing options...
Chad Warner Posted August 9, 2005 Share Posted August 9, 2005 What software? Link to comment Share on other sites More sharing options...
chow choppe Posted August 9, 2005 Author Share Posted August 9, 2005 Adobe Premiere... haha chad that was fast... I was editing my original post when u were replying Link to comment Share on other sites More sharing options...
taprice Posted August 9, 2005 Share Posted August 9, 2005 Did you use the timeline to select the portion of the movie you wanted. It has been a while since I've used Premier but that would be the advise I have. Link to comment Share on other sites More sharing options...
chow choppe Posted August 9, 2005 Author Share Posted August 9, 2005 Hi tim i mentioned it that i am using that technique by making the timeline cursors within that limit.... the trick we use in "render work area" while taking a preview but it isn't helping Link to comment Share on other sites More sharing options...
Bugga_Guy Posted August 9, 2005 Share Posted August 9, 2005 I know there is an alternative way that you mentioned, but you can also just create a new video bar, cut the portion of animation you want to export out and place it in the new time slot, and turn the eye off for everything else but the new timeline (except what for the animation you don't want to turn off).. Link to comment Share on other sites More sharing options...
Chad Warner Posted August 9, 2005 Share Posted August 9, 2005 With premiere pro, there is an option in the export settings to export only the work area or the entire project. I think there is a similar option in premiere 6.5 and 6. Link to comment Share on other sites More sharing options...
chow choppe Posted August 9, 2005 Author Share Posted August 9, 2005 ok i got the solution. make ur work area bar that much size as i mentioned and go to file --->export and then settings and then in general got to range and change from entire sequence to Workarea bar... thats what was the trick anyways thanks for the help Link to comment Share on other sites More sharing options...
