chow choppe Posted August 9, 2005 Share Posted August 9, 2005 Here is another question from after effects... This is about keyframes... how can i jump to a specific keyframe i mean if want my time slider to go 1 second and 23 frames how can i do that. Secondly how can i copy one keyframe from one point to exactly some other pont.For example i want to copy my keyframe at frame no23 to 1second and 24frames... I know it cud be easy for u but i am trying to learn after effects...i am enjoying it...After effects is cool... Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted August 9, 2005 Share Posted August 9, 2005 to copy a key frame, just select the key, and hit ctrl c, then go to where you want it, and hit ctrl p. to go to a certain spot, click the time marker at the bottom of the comp preview window. it will look smething like 0:00:49:28. when you click it, and box pops up, and you can key in to where you want to go. Link to comment Share on other sites More sharing options...
Nils Norgren Posted August 10, 2005 Share Posted August 10, 2005 You can click on the timcode in the Comp, and type in the code of where you want to be, for 1 sec 23 frames type 1.23, what is cooler is that you can type +30 and move RELATIVE 30 frames in time, to move backward relatively however you have to type + - 30, that is a PLUS a SPACE then a MINUS and then the number of frames or timecode. Also remember that under File -> project setting you can change the timecode to frames or feet or whatever. Some day it would be nice to have both frames and timecode active at the same time. Enjoy, AE is an Awesome tool -Nils Link to comment Share on other sites More sharing options...
chow choppe Posted August 10, 2005 Author Share Posted August 10, 2005 Thanks a ton Link to comment Share on other sites More sharing options...
