Ged Trias Posted August 10, 2005 Share Posted August 10, 2005 Is there a way to convert an ADT drawing to regular 2d autocad outside of ADT? I have a consultant drawing in ADT and no access to ADT to convert. Exploding and exporting have proxy object problems. I don't want to lose the doors. Your help is appreciated. Link to comment Share on other sites More sharing options...
Videha Posted August 10, 2005 Share Posted August 10, 2005 download the right objectenabler from the Autodesk website this should solve your proplem if there is none for your version Autocad. Ask your consuldant to explode the ADT file in plan view 2 times and save it as dwg 2000 or 2004 file hope it helps seeya Link to comment Share on other sites More sharing options...
Fernando Lino Posted August 10, 2005 Share Posted August 10, 2005 they just need to export it to Autocad 2000/2002/2004 There is a tool in ADT "explode AECelements" or Hidden line projection under document all these ways are inside of ADT....talk with your consultant...export it to Autocad don't take more than 1 min. Link to comment Share on other sites More sharing options...
Kerry Thompson Posted August 18, 2005 Share Posted August 18, 2005 I also create a plan using the section tool (a plan is a section on its side) and then explode it and copy the results to a new file. While the "explode AECelements" does the job, there are still ADT residues in the file. Cheers Kerry Link to comment Share on other sites More sharing options...
Buttman Posted September 10, 2005 Share Posted September 10, 2005 U can do into hidden sketches and explode it but it'll end up very high Mb file because of the thousands lines. Link to comment Share on other sites More sharing options...
