roland Posted August 11, 2005 Share Posted August 11, 2005 hi guys, i have a problem in vray. 1. light is leaking 2. material texture hope any one can help me out. thank you, Link to comment Share on other sites More sharing options...
ipdesigner Posted August 11, 2005 Share Posted August 11, 2005 *what type of light did you use? and its parameters? Link to comment Share on other sites More sharing options...
JamesTaylor Posted August 11, 2005 Share Posted August 11, 2005 under irridance map in the render dialog box make sure "check sample visablity" is ticked. should remove the light leak Link to comment Share on other sites More sharing options...
roland Posted August 13, 2005 Author Share Posted August 13, 2005 ipdesigner said: *what type of light did you use? and its parameters? i only use direct light with vray shadow Link to comment Share on other sites More sharing options...
ipdesigner Posted August 13, 2005 Share Posted August 13, 2005 roland said: i only use direct light with vray shadow *thats okey, and the parameters? Link to comment Share on other sites More sharing options...
roland Posted August 13, 2005 Author Share Posted August 13, 2005 ipdesigner said: *thats okey, and the parameters? bro, i dont have the file with me so i cant tell you exactly the parameter. Link to comment Share on other sites More sharing options...
