Flying Birds
Devin Johnston
Hi Devin,
Maybe pick up some exisiting footage of real birds flying over?
Make sure the background is transparent and have it in a layer on top of your animation with a few mouseclicks (in premiere pro).
I suppose this is the most easy and photorealistic solution for a bunch of birds in the sky...
Dennis
I believe poser has birds or at least 1 bird. You can animate the wings render the anim frames out and composite them in with after effects.
Thats how a company I used to work for did it. There is also a plugin to import poser models in with anim. but I forget the name.
Hi,
Check the resolution of the birds first. Most of the time you can get away with a simple 5-box-object and animating them. Use the maybridge-books for animals as a reference.
Make one animated cycle and use them distrubuted in a particle system...
In this animation (from 2001) almost every daytime shot has birds animated as described above... "Villa Sarra" http://www.ams.be/sitev2/public/en/ProjListB.asp?ProjTekst=villa+sarra&ID=49&tot=1&nr=1&Land=
for other animations: http://www.ams.be/sitev2/public/en/trailers.asp
rgds
nisus
