1eo Posted August 12, 2005 Share Posted August 12, 2005 In Rhino 3D you can select an object and scale it in: - "2 directions" = the object is scaled the same % in the "X" and "Y" axis. - "3 Directions" = same as # 1, but the object is also scaled in the "Z" axis and finally - "1 direction" = the object is scaled only in the direction that I comand. Example I could scale one or many objects in the "y" axis 125% while the "X" axis stays the same ( %100) In Autodesk 2006 I only know how to do "2 directions"... how could achive scale "1 direction". the "Stretch" doesn't quite do it either Thanks in advance!!! Regards, Leonardo (BTW what I'm trying to scale are 2d lines... nothing else) Link to comment Share on other sites More sharing options...
1eo Posted August 12, 2005 Author Share Posted August 12, 2005 Oh guys.. please let me know if my question is not clear enough Link to comment Share on other sites More sharing options...
puciorek Posted August 12, 2005 Share Posted August 12, 2005 after selecting an object-block, go to modify properties dialog box and while in there, you could change separately scale factor %, at least that's what I was able to do in cad2004. see attached: Link to comment Share on other sites More sharing options...
1eo Posted August 12, 2005 Author Share Posted August 12, 2005 it works!!!.... thanks a lot!!! you save me some good time Regards, Leonardo Link to comment Share on other sites More sharing options...
Antisthenes Posted October 5, 2006 Share Posted October 5, 2006 not nearly as usefull as scale1d witch is not axis dependent. thats one of my Favorite Rhinoceros commands Link to comment Share on other sites More sharing options...
