Esteban Gonzalez Posted August 13, 2005 Share Posted August 13, 2005 Hey People...... i need opinons, about this residential proyect....... this work i did in about 4 hours.... yesterday.... thankssss Esteban EDGE archs. labs Link to comment Share on other sites More sharing options...
Bugga_Guy Posted August 13, 2005 Share Posted August 13, 2005 For 4 hours it is quite good.... but then again it kind of look like it was done in 4 hours. Overall its very flat, and your renderings are in the place I like to call the "neutral zone" too unfinished to be realistic, too much detail to be a block model. you have to many mixed elements - ie blocked palm trees/cars standard lighting. But you have colours, bumped water etc. If I were you, I would replace the blocked trees with more realistic trees (even opacity maps would look better), and same goes with the cars. Also some GI would improve it alot - or at least some fakeosity. Avoid copying elements in the scene (ie shrubs, trees) if you must, at least change the sizes, place different textures. Also you have squishy people - The thing about people is if they don't look proportioned correctly - DONT PUT THEM IN! The result can be very damaging. So either fix with width of the coupple or take them out. Link to comment Share on other sites More sharing options...
oyie Posted August 14, 2005 Share Posted August 14, 2005 not bad...lighting is good, but you have have to work on your material and texture. what happen to your peole on the 2nd image, its look like its been stretched Link to comment Share on other sites More sharing options...
