mbr Posted August 15, 2005 Share Posted August 15, 2005 How do you get rid of mullion flickers with scanline animations? Suggestions for AA settings? Everything else is rock solid, but those damn mullions flicker like mad! Thanks. Link to comment Share on other sites More sharing options...
Tiny Piney Posted August 15, 2005 Share Posted August 15, 2005 It could be because of the raytrace AA. If the glass is reflecting the mullion it will cause it to flicker. In the raytrace settings turn on the AA this doubles the render time but should solve it. Link to comment Share on other sites More sharing options...
mbr Posted August 15, 2005 Author Share Posted August 15, 2005 Ok, so the RT AA settings, not the regular AA settings? It's set to (checked) Fast Adaptive Antialiaser Should I change that or change it's settings? Thanks Link to comment Share on other sites More sharing options...
Tiny Piney Posted August 15, 2005 Share Posted August 15, 2005 That usally works for me. Cheers Link to comment Share on other sites More sharing options...
mbr Posted August 15, 2005 Author Share Posted August 15, 2005 It was on for the rendering. Anyone know if I should (and how) change the AA settings, either in the RT panel or the regular AA panel? Link to comment Share on other sites More sharing options...
Tiny Piney Posted August 15, 2005 Share Posted August 15, 2005 does anything else flicker? is it just the mullions? double check to see if the there are two overlapping faces. or try excluding the mullions from the raytrace. Link to comment Share on other sites More sharing options...
