mbr Posted August 16, 2005 Share Posted August 16, 2005 How do you crop in Premiere? So if I have a video that's 640x480, but I want to cut off X amount off the top and bottom? Can I do that without starting a new project? Thanks. Link to comment Share on other sites More sharing options...
raterry Posted August 16, 2005 Share Posted August 16, 2005 Sure, it's pretty simple. There's are couple ways to do it but best is to make a mask in Photoshop that has black on top and bottom and white where you want to see your image. save it out. Make sure your clip is in "video 2" or higher, 1A and 1B wont work...select the clip you want to crop, right click and select "video options" > "transparency" Select "image matte" for the key type and navigate to the file you just created in photoshop. Hit OK and your done. Good Luck. -=rob Link to comment Share on other sites More sharing options...
mbr Posted August 16, 2005 Author Share Posted August 16, 2005 Hmmm, thanks, but that options not coming up. I've got the video in Video 2. Right clicking does not bring up "video options". If I go under Clip, there is the "video options", but it only has Field Options. Is there another approach or am I missing anything? Link to comment Share on other sites More sharing options...
mbr Posted August 16, 2005 Author Share Posted August 16, 2005 Ok, for now a psd with transparent center and black edges will work. It'd still be nice to figure it out, though. After Effects seems so much more intuitive than Premiere! Link to comment Share on other sites More sharing options...
