RAYMOND Posted August 16, 2005 Share Posted August 16, 2005 how do you create a ps vp for a random sized retangle for plotting an image. example have a 3dface that encompasses an odd shaped parking lot. and need to produce an image that will fit the 3dface in viz... but can't seem to figure out how you could do this paper space.... as of now have to do a screen capture then crop it in photo shop... of course everytime one does this it is slightly off from the last time.. if it could be set up in paper space.... no worry... also, can't seem to recieve email notifications from replies on this forum??? thanks ahead... Link to comment Share on other sites More sharing options...
William Alexander Posted August 17, 2005 Share Posted August 17, 2005 Haven't done it in a while and not in 2004, but can't you plot the paperspace to jpg? Have you checked you spam folder for those missing notifications? WDA Link to comment Share on other sites More sharing options...
vizwhiz Posted August 17, 2005 Share Posted August 17, 2005 Ray you can create a PS viewport using a polygon boundry for whatever size and shape That you are needing To plot To ** also and/or otherwise if you can look for and download CutePDF (free) plot software for autocad, Then you can plot to scale and Trim as needed in FotoChop just create The boundry before plotting and Trim in FotoChop later ** i plot 2d Elevation lines at 300 dpi for a 36x24 sheet Then import the colored VIZ renderings into the same PDF file well it is a PSD file by Then and use the PDF plot info as The background to match up the viz output i Think That There is a (Free) ghostwriter component That goes with The CutePDF writer which will automatically install into autocad plotting we have This at work and i have also done This at home it works There are other PDF writers other Than CutePDF This is just The one software That i am familiar with go to google go do google Thanks Randy (hey can i get a week free stay on one of The Islands?? subliminal hint goes here) Link to comment Share on other sites More sharing options...
