Tim Saunders Posted August 16, 2005 Share Posted August 16, 2005 any one ever seen this error. i get it about a minute after i hit render, then after clicking ok it just closes the render window. i am using radiosity for this scene. i had to abort vray for this one. it is a pretty complex interior with way to many lights. vray just takes way too long for that many lights. it was working fine until i put a few more lights in. is there such thing as too many lights? Link to comment Share on other sites More sharing options...
Bugga_Guy Posted August 16, 2005 Share Posted August 16, 2005 I don't use vray, but I have seen that error (mostly in big scenes with alot of lights w shadows) - to answer your question about lights its more the shadow than the actual light. See if you can delete the number of lights, if not, turn shadows off for some of the lights. If you are using a light with a shadow bitmap - you can reduce the "size" value in the shadow map param box setting. Link to comment Share on other sites More sharing options...
Tim Saunders Posted August 16, 2005 Author Share Posted August 16, 2005 i just reduced the number of lights. seams to be rendering okay. Link to comment Share on other sites More sharing options...
Christopher Nichols Posted August 17, 2005 Share Posted August 17, 2005 you using shadow maps? Link to comment Share on other sites More sharing options...
Tim Saunders Posted August 17, 2005 Author Share Posted August 17, 2005 yeah i am, but like i said. once i reduced the number of lights, things are working okay now. i f you have a remedy i would still like to know though. Link to comment Share on other sites More sharing options...
Brian Cassil Posted August 17, 2005 Share Posted August 17, 2005 Hey Tim, Select your light, go to shadow map parms and in the size box reduce the value from 512 to 256. Or better yet go to tools menu, then light lister and you can adjust the map size for all the lights right there. Link to comment Share on other sites More sharing options...
Tim Saunders Posted August 17, 2005 Author Share Posted August 17, 2005 thanks brian, oh, and get back to work. i thought you had a bunch of deadlines. Link to comment Share on other sites More sharing options...
Wayne Harney Posted August 17, 2005 Share Posted August 17, 2005 I get that often with shadow maps and usually I can shut down viz and restart it. Then it works fine. Pain in the ass though. Link to comment Share on other sites More sharing options...
Brian Cassil Posted August 17, 2005 Share Posted August 17, 2005 oh, and get back to work. i thought you had a bunch of deadlines. rendering;) Link to comment Share on other sites More sharing options...
