Tommy L Posted August 17, 2005 Share Posted August 17, 2005 aaaaaah! Whats that black thing on the ceiling? Still from an animation using viz6 and vray. I thought at first it was an irradience map problem (nope) then a geometry problem (nope) so... Any ideas? Cheers, Tom. Link to comment Share on other sites More sharing options...
STRAT Posted August 17, 2005 Share Posted August 17, 2005 Aliens!!!! Link to comment Share on other sites More sharing options...
Tommy L Posted August 17, 2005 Author Share Posted August 17, 2005 Aliens!!!! Silly me, forgot to un-check the 'ceiling alien' setting.... Link to comment Share on other sites More sharing options...
Brian Cassil Posted August 17, 2005 Share Posted August 17, 2005 My guess would have been coplaner faces on the ceiling. Link to comment Share on other sites More sharing options...
Tommy L Posted August 17, 2005 Author Share Posted August 17, 2005 My guess would have been coplaner faces on the ceiling. Thanks Brian. It looks like, its smells like it and it sounds like it. But it aint. Bummer. Link to comment Share on other sites More sharing options...
bokkins Posted August 17, 2005 Share Posted August 17, 2005 cut those frames that are affected, it wont affect the output... not unless its a plague. Link to comment Share on other sites More sharing options...
mbr Posted August 18, 2005 Share Posted August 18, 2005 I'd try adding a new ceiling, just an inch or so below. Try rendering, if it works you are all set. If the artifact is still there, than it's the GI. Personally, I've found that objects, for whatever reason, can do weird things with GI. I've had to rebuild random walls, usually because of some modifier or boolean. Link to comment Share on other sites More sharing options...
Dynedain Posted August 18, 2005 Share Posted August 18, 2005 Like you thought at first, it is an irradience map problem. You rendered the irr map every nth frame, and now when you use the saved irrmap, you are missing some data necessary for this particular view. That, or something moved between the irrmap calcs and this rendering. What you're seeing is simply missing lighting data. Link to comment Share on other sites More sharing options...
