ecastillor Posted August 17, 2005 Share Posted August 17, 2005 I have 4 machines running on windows xp pro and one windows 2000 pro... but neither of the configured as a server...can I go about setting up a render network with this setup? do I need a server?..im using viz and want to use the backburner and vray and want to use render network...thanx Link to comment Share on other sites More sharing options...
Brian Cassil Posted August 17, 2005 Share Posted August 17, 2005 The only thing you need to bear in mind is that all the machines need to be able to "see" the bitmap paths and the out path for the final image(s). None of the machines need to be set up as a server per se, but they do need to be able to share information between each other. Link to comment Share on other sites More sharing options...
ecastillor Posted August 17, 2005 Author Share Posted August 17, 2005 Well, that I have...they all see each other...how do I configure viz for net render? Link to comment Share on other sites More sharing options...
vertexART Posted August 17, 2005 Share Posted August 17, 2005 Hi there, dunno about Viz, but this is how it's done in Max, I guess it's similar for you too... 1.U need the program running on a single machine 2.start 'backburner>server' on all machines U want to use. Under 'general setting' U should configure subnet mask to look for 'manager's machine' IP. 3.start backburner>manager on machine that's running the program. there U should see if the previously configured server is found... hopefully. 4.under render dialog, U should have options like 'output' file path, where U can store the rendering. Also, there must be a check box or something to enable 'net render', which will trigger a new window.... in which U have a list of all available machines, so U can choose which one to assign to a job. 5. I just hope it helps a bit.. Cheers Link to comment Share on other sites More sharing options...
ecastillor Posted August 18, 2005 Author Share Posted August 18, 2005 yes it did..thanx! Link to comment Share on other sites More sharing options...
anvaraziz Posted August 18, 2005 Share Posted August 18, 2005 on v-ray they have Distribute rendering,,, very usefull stuff it is... Link to comment Share on other sites More sharing options...
AJLynn Posted August 19, 2005 Share Posted August 19, 2005 Try it with VRay's distributed renderer - Backburner will assign frames to each machine, which is useful for animation or queuing, but if it's one big still you're doing, not useful. VRay's distributed renderer will split the work of a single frame between computers, and it's pretty efficient. Run VRaySpawner on all the render node machines (not on the machine you're running Max on) and put all the other computers' names into the distributed render settings under System rollout in the Renderer tab. Link to comment Share on other sites More sharing options...
