joseph alexander Posted August 18, 2005 Share Posted August 18, 2005 Very new to Vray.. Working from the demo version.. I'm getting big blotches where my furniture and floor meet... is this a modeling issue our a settings issue? -Joe Link to comment Share on other sites More sharing options...
pablo scapi Posted August 18, 2005 Share Posted August 18, 2005 Try to tick the "check sample visibility" option in the ir map menu. The scene is also very dark, how ar you ligthing it? Try to post a wireframe where we can see the scene and lights. That leaks could also be due to bad modeling, is hard to tell. Link to comment Share on other sites More sharing options...
DennisHolland Posted August 18, 2005 Share Posted August 18, 2005 If you use a directional for a sun then check your shadows, it should say vrayshadow or shadowmap. Or the demo doesn't support vraylights and therefore using a maxlight + regular shadows? That is not working (well). Maybe check this: - Did you check the demo restrictions properly? It could be a scramble. - Those things also happen when you add objects after calculating your lightcache/irr. map. - Check outline and set normals to 0.00. - Change AA filter to Catmull-rom or Mitchell Netravalli. The rest of the settings are pretty ok. Link to comment Share on other sites More sharing options...
a_rockyheart Posted August 21, 2005 Share Posted August 21, 2005 use vray shadow instead. assign default scanline and reder, next, assign vray as current render to reset your IRRmap and Lightmap. if the problem still there, i think u have to reassign all reflect/refract materials in UR scene. Have fun! Link to comment Share on other sites More sharing options...
