Aspiring Visualizer! Posted August 18, 2005 Share Posted August 18, 2005 I have a project that has to be completed fairly quickly in Architectural Desktop, however I have one big problem!!.... How do I place a double hung window in a curved wall so that it curves and matches the arc?! I do not want to use a curtain wall window, and I really do not want to create a new window, as I don't have the time. Is there any possible way of curving the existing Double Hung window to match the curvature of the wall???!! Thank you soo much for any help! Link to comment Share on other sites More sharing options...
RAYMOND Posted May 2, 2008 Share Posted May 2, 2008 I don't think there is a way to make a curved DH window. however, you can drop in windows into a curved wall providing the geometry will alow it... ussually window in curved walls are quite narrow is this the case. Link to comment Share on other sites More sharing options...
Brian Smith Posted May 2, 2008 Share Posted May 2, 2008 I have a project that has to be completed fairly quickly in Architectural Desktop, however I have one big problem!!.... How do I place a double hung window in a curved wall so that it curves and matches the arc?! I do not want to use a curtain wall window, and I really do not want to create a new window, as I don't have the time. Is there any possible way of curving the existing Double Hung window to match the curvature of the wall???!! Thank you soo much for any help! just apply the subdivide modifier (using a small max face size) and then the bend modifier. bend in top view to match the wall, but you will probably have to change the axis around which the bends takes place. Link to comment Share on other sites More sharing options...
