NEW Villa ( BRAZIL Render )
ibrahim_jalloul
That's pretty good stuff. Couple comments-
I don't like the way the vertical corners of the stone material are perfectly straight - with the amount of texture in the material, this should show in the profile of the edges. I don't know much about Brazil, but this might be a good place to use a displacement map.
Also, in the second image, the right foreground is not at the same level of realism as the rest of the shot. I think there are a few things giving me that impression - the perfect edge between the wall and the grass, the camera distortion making it "pop" quite a bit, and the focus - using depth of field might help you here.
Editing cause I saw one other thing-
The stone texture on the house is not "seamless" - you can see the tiling lines where the color changes.
