Intuos under XP
Do any of you have a Wacom Intuos2 attached to an XP box using Photoshop 7 -- and does it work properly? PS reads the tablet data just fine in term of cursor movement, but not the pressure data. It had work flawlessly on my other computer with the same version of PS but W2K.
I had DL'ed the newest driver and it worked with pressure the first time, but never again. Uninstall the driver, re-install, same, no pressure. I have tried setting up PS as a targetted app in the Wacom control panel, and tried it in generic mode, too.
Any ideas? Does yours work?
Hi Ernest,
I use an intuos2 with ps7 on XP without any problem at all.
- Did you use a pressure sensitive brush?
- Have you configured the wacom accordingly?
- Do you use pen mode?
- Do you switch between other programs while using it? (In my case, when working in ps and starting another application at the same time, causes an full pressure brush. Change back and forth to ps and it's fine again)
rgds
nisus
I have an Intuos 2 on Win2K Pro and have the same problem to some extent.
I had no problem with Photoshop 5.5 then I upgraded to Photoshop 7 and it very rarely recognises pressure sensitivity.
I usually have to launch photoshop 4 or 5 times testing it each time until it launches recognising sensitivity.
  • 2 weeks later...
