radioVOY Posted August 22, 2005 Share Posted August 22, 2005 hi everyone!!! im working in a large project with a lot of detailed landscaping, the problem are the loans, have a lot of plants with flowers covering all de grass, and the plants are specific ones, does anyone knows a good tutorial to simulate this geometry or build a low poly plants, or a link where i can find specific plants??? Link to comment Share on other sites More sharing options...
Msamir Posted August 22, 2005 Share Posted August 22, 2005 Hi Ever hope this helps http://www.cgarchitect.com/vb/showthread.php?t=11682&highlight=vizup Link to comment Share on other sites More sharing options...
vizwhiz Posted August 23, 2005 Share Posted August 23, 2005 ola Ever what kind of plants are you looking for? Tropical, desert or suburban plantscapes?? (dont know what else To call it) check These out and let me know if it is anywhere close ?? i am sure That Others will have other links, This is 2d billboard or no poly plants, i use These at work in both VIZ and Photoshop ** main homepage link is http://www.imagecels.com/ Trees: http://www.imagecels.com/im01000.html#207 more Trees: http://www.imagecels.com/thumnail/113/113.html desert shrubs: http://www.imagecels.com/im01000.html#207 desert Trees: http://www.imagecels.com/Plants/desert_trees_images.html Tropical Trees: http://www.imagecels.com/thumnail/116/116.html Palm Trees: http://www.imagecels.com/Plants/pts3_palms_clipart.html flowers and blooming plants: http://www.imagecels.com/Plants/flowering_thumbs.html * The nice Thing about bitmaps Trees and shrubs is That you can apply These to a plane and link to a "dummy" That is linked to a specific camera so if you end up changing your camera point of view Then The plant planes will rotate To continue To face The camera duplicate The same plant Image and link to a dummy That links to The Sun make This 2nd plant "invisible" to render so it will cast a shadow but not show up in The Image, This way cool if you change your light source or sun angle * if necessary you can grab a digital camera and Take some photos of The "exact" plants required for your arch Image and composition ** Archvision has some 3d RPC plants http://www.archvision.com/ ** i hope This helps i live in Arizona not Too far North of you Randy Link to comment Share on other sites More sharing options...
