Devin Johnston Posted August 22, 2005 Share Posted August 22, 2005 I'm using a compound material that is made up of cellular and noise procedurals and during my animation the material seems to vibrate a little bit. I’ve turned 2 sided on the material which has helped a little but still not enough to get rid of the vibration. Does anyone know of a way in Max 7 to get rid of this movement? Link to comment Share on other sites More sharing options...
Bugga_Guy Posted August 23, 2005 Share Posted August 23, 2005 make sure that materials have not been accidentally been animated - also try increasing your supersampling. Link to comment Share on other sites More sharing options...
Paulcalif Posted August 23, 2005 Share Posted August 23, 2005 Bugga is right on with the second. The noise is too small, and looks fine rendered as a still, but appears animated when rendered in an animation--even though the material itself is not animated. Increase the size of the nois, or use supersampling as he sugested. Link to comment Share on other sites More sharing options...
chutti Posted August 23, 2005 Share Posted August 23, 2005 Hey though they are procidural mats try using UVW modifier on your object. Link to comment Share on other sites More sharing options...
Devin Johnston Posted August 23, 2005 Author Share Posted August 23, 2005 Thanks guy's I'll try that and let you know how it works! Link to comment Share on other sites More sharing options...
