Interior Bathroom
Martinjc1
Hi Martin
I'm sure you know this already but it's way too dark.
You have bright sunlight coming in and it's hardly illuminating the room at all.
Modelling and texturing look good but it's hard to tell.
Keep updating and posting.
Hi all thanks for your replies. I have attached 2 more images of the same bathroom. The First image i have made brighter using photoshop, the second image i have added a ommi to the dark corner with a low multiplier. This has made the image brighter, however I think it looks unatural or unrealistic. Also the second image seams to be made up from large blocks, is this a lighting map problem.
Thanks once again for you comments. I really aspire to acheive results similar to others I have seen in this and other forums, fantastic.
Looks like 3ds max and Vray. You need to adjust the render settings to get a better render quality also you don't need all that information at the bottom, you can remove some of the info in the 'system' tab in the render settings.
Good for a first attempt. Try set omni light to 'ambient only' or use a vray light with low multiplier to brighter up the bathroom.
