problem with section precision in ADT2005
emen
im using section commandgenerate section> on a block consisting 10 solids - problem is that the result varies in precision from model - distances 18,36 cm are 18,4 or 18,3
drawing setup is centimeters precision 0,00 , section style standard... :confused: anyone?
You're not accidentally getting these dims from a dimension line that you have added are you? When I first started out I found that I had done this because I was not zoomed in enough and I was picking up the dimension offset.
Just a thought!
