Lupaz Posted August 26, 2005 Share Posted August 26, 2005 Is it possible that I have such trouble to do a simple geometry like this in 3dsMax? I did some rectangles, extruded them, converted to editable poly, erase a lot of "invisible" edges, then apply chamfer, and it was a disaster! Then checking on this forum found that it was better to apply edit mesh as a modifier. It was pretty good until this window. Someone? any ideas how to create a window like this with chamfers?? tnx here is the illustrator file with the curve: Illustrator spline http://cablemodem.fibertel.com.ar/lupaz/Bowcat/chamfer01.jpg Link to comment Share on other sites More sharing options...
mbr Posted August 26, 2005 Share Posted August 26, 2005 are you trying to make a beveled edge? for simple bevels you can Edit Poly > Bevel and specify the exact size. I never use the chamfer, simply because it becomes a mess so quickly. All in all, though, Max is not a great modeler for architecture. I loved FormZ's Round feature - just click on what you want, spec the # of facets and size, and it makes the edges as round as you want. As far as I know, there is no easy way to do this in Max. Link to comment Share on other sites More sharing options...
Lupaz Posted August 26, 2005 Author Share Posted August 26, 2005 isn't there a "shame smiley"? Bevel works just fine! I 'm sorry I didn't ask before. I've wasted so much time with chamfer... MBR: do you export from FormZ to Max for rendering? what about the mesh? it stays clean in Max? Thanks Link to comment Share on other sites More sharing options...
mbr Posted August 26, 2005 Share Posted August 26, 2005 It should stay mostly clean. Export as a dwg, or a 3ds if you are having problems (dwg will make all objects on a layer a single mesh in max, which can be nice for organization - ie layer 'glass' will be object 'glass' in max, 3ds will assign random names - ie object00000012). Link to comment Share on other sites More sharing options...
Brian Cassil Posted August 26, 2005 Share Posted August 26, 2005 Yeah, I've been waiting patiently for better "chamfer" and "fillet" options in max since version 1. It's silly that it's still such a pain. Link to comment Share on other sites More sharing options...
