Michael Earley Posted August 28, 2005 Share Posted August 28, 2005 I have been given a model to use in an animation.when I opened it in autocad, I found that most of the model was there as a proxy. I dont have access or time to get the missing files. I imported the dwg file(a very detailed train cab) and it is one big editable spine with 2 million vertixs. I have tried to convert it to a mesh, but nothing shows in the model except a few pieces. If I select vertix in the modifer list, the vertixes are there, but not connected. There are too many to try to connnect them. Is there a way to weld them all or modifer to use to show a surface? I imported with autoweld set to .003 and tried many others and still have this problem. Michael There are almost 2 million vertrices and 4 million faces in the model. the model itself is not very large, 5 mg but the designer over complicated the model. Link to comment Share on other sites More sharing options...
Grumpf Posted October 23, 2007 Share Posted October 23, 2007 If The original proxy model is missing U have no solution except modelling again... If U need to simplify your splines use "Normalize" in the edit roll Out... if U want to surface your spleen U have to make a spline network and use surface... Link to comment Share on other sites More sharing options...
