frank1331 Posted August 31, 2005 Share Posted August 31, 2005 Using Viz 4 and Vray basic. I can't figure out why the tiled roof in the background will not render the same as the one in the foreground. Exact same material, map size, etc. Using a single direct light with vray shadows. I even tried making a copy of the one in the foreground. But as soon as I render it, this happens. Is it a falloff issue? I'm running out of time. Thanks Link to comment Share on other sites More sharing options...
ecastillor Posted August 31, 2005 Share Posted August 31, 2005 Ive never had that sort of a problem....what version of vray R U using? If youre runnig out of time and everythig else fails, there's always our beloved pal Photoshop... Link to comment Share on other sites More sharing options...
ecastillor Posted August 31, 2005 Share Posted August 31, 2005 BTW...R those palms RPC? if so..how do they cast shadows? Link to comment Share on other sites More sharing options...
frank1331 Posted August 31, 2005 Author Share Posted August 31, 2005 Yes the palms are RPC. Shadow just falls along the same angle as the camera. I tried pulling some of the yellow with Pshop, and it looks ok for what I need it for. I was just wondering on what caused it. One other quick question. Is there a way to put some type of transparency gradient on the water? So it appears more transparent near the shore. Link to comment Share on other sites More sharing options...
Tim Saunders Posted August 31, 2005 Share Posted August 31, 2005 align the shadows with your sun, not the camera. it looks a bit wierd having the shadows of the building and the trees at all different angles. Link to comment Share on other sites More sharing options...
