samsung 191T+
r2
Hi guys,
I made a booboo and ordered the 191T+ on the newegg site. Originally, I wanted the 191T soo now I'm trying to find some more info on this LCD. On the samsung site it says the contrast ratio is 750:1 whereas the 191T is 700:1. Is that the only difference? is the 191T+ a newer version of the 191T? Should I try to return it
thanks
it arrived and i plugged it in. WOW this thing is amazing! i even gave it a run on CS and q3. theres a very minimal amount of ghosting. i dont know why everyone complains about games and LCDs :gebigeek:
now all i need is a video card with a DVI connector. yes im running analog. anyone know of a good 4x agp card that would work for 3dsVIZ? do 8x cards run in 4x slots?
thanks
A contrast ratio of 700 to 1, are you sure ? I've heard anything between 200 and 300 to 1 is eye pleasing, everything else is no good and hurts your brain. So how is it working for a few hours staring at the monitor ?
just curious
greets Ingo:
the contrast ratio on this screen is 750:1. but i'm currently running analog so i dont know if that makes any difference. however i can tell you my eyes are much more pleased. i've used it for 16hrs straight now. i once had alot of doubt about buying a LCD but now any doubt is erased. this input coming from working on a 21" mitsubishi crt - .24 dot pitch @ 85hz. i dont think i can stare at that monitor at work anymore.
for more info check out the samsung site:
http://www.samsungusa.com/cgi-bin/nabc/product/b2c_product_detail.jsp?eUser=&prod_id=191Tplus-Silver
thanks
r2 - You'll benefit greatly from running DVI cable. Really sharp and higher contrast than analog. It's like night and day difference with this monitor (I have the 191T). The main differences between the 191T and 191T+ is the contrast ratio, built-in power adapter (AC-DC converter), and I think some USB plugs in the base (maybe). Check the samsung website for more detailed specs comparison. Just for information sake's, in Europe the 191T+ is labeled 193T. Same monitor different name.
ingo - I use it for hours on end (normally 8 hours a day with the normal amount of breaks) and I get no eyestrain or headaches, which would always happen with my old 17" Sony Trinitron CRT. LCD is just much better for your eyes' health. Now if I could ust get another one and run dual LCD's. ;)
soooo i decided to take a break and play some more quake3. i really dont know what people meant by ghosting but it looks just like the way i played it on my CRT. the smoothness and colors were very cool except for the parts where i kept getting fragged :ngeupset: . that is all.
I second the recommendation for LCD's, as well as the push for DVI-I.
Huge difference in the 191T's with DVI-I.
Its just incomparable.
The other secondary benefit of DVI-I, is there is no RFI filtering issues with older Geforce cards.
(Aka gets rid of the blurriness at higher res's).
