neil poppleton Posted September 6, 2005 Share Posted September 6, 2005 certain machines on our renderfarm display the following message and will not render anything until the user selects ok ? '''An attempt was made to load a program with an incorrect format'' we use viz 05 and 06 and not seen this before , has anybody had a similar excperience ? Link to comment Share on other sites More sharing options...
Devin Johnston Posted September 7, 2005 Share Posted September 7, 2005 I think your problem is that when your trying to render a scene on a computer with Viz 6 that was created on Viz 5 your getting a message that says your using an old format. I'm pretty sure that the only way to get rid of this message is either to save out the file in the newer format, or to install the same version of Viz on all your machines. Link to comment Share on other sites More sharing options...
neil poppleton Posted September 7, 2005 Author Share Posted September 7, 2005 we have both viz 05 and 06 on each renderfarm pc, and once you ok this error message manually then it carries on rendering???? odd, not seen it before Link to comment Share on other sites More sharing options...
Devin Johnston Posted September 7, 2005 Share Posted September 7, 2005 So you have bot Viz5 & 6 running as a service at the same time? How do you know that the jobs your sending to Viz 5 are being rendered by it and not by Viz 6? Link to comment Share on other sites More sharing options...
