FMNG Posted September 14, 2005 Share Posted September 14, 2005 hi guys, i have a lighting question that i don't understand why. hope you guys out there can give me a light here is the case. the image above with only 2 Omi light, which is one omi Light is with "Ambiant only" and "Far Attenuation" is activate. For the second Omi light is only "Deffuse and Specular" with no "Far Attenuation" apply. as you can see, the shading was circle up is so soft and nice. this is what i expected. here the problem is. This scene also with only 2 Omi light, one is with "Ambiant Only" and "Far Attenuation" is activate. For the second Omi light is with "Deffuse and Specular" with "Far Attenuation" apply too.but how come the shading was circle up was so sharp and hard?. i really dont' know why... here is the sample file Help thanks Link to comment Share on other sites More sharing options...
vertexART Posted September 14, 2005 Share Posted September 14, 2005 hi there, seems like your difference between far attenuation start & end is too small. U should try either lowering your far>start or increasing far>end, or maybe both. U can try with a different shadow type but that will depend on the renderer choice. hope it helps. Link to comment Share on other sites More sharing options...
FMNG Posted September 15, 2005 Author Share Posted September 15, 2005 hi vertexArt. i don't think is the far>start or far>end problem, it is fine if i create a new omi with far attenuation is apply but without stracthen it with uniform scale. the hard shading is only appear when i stracthen the far attenuation to fit to sub-object. Link to comment Share on other sites More sharing options...
