jtiscareno Posted September 14, 2005 Share Posted September 14, 2005 I am trying to create a vct pattern and since it is specific I was going to create the material from scratch, I have done it before in Viz4 and it came out almost the same as the real thing. Now I tried to use the Blend material on the material editor and it is not there???? I am using Viz6 with Vray, does anyone what happend to blend? I went to the user refrence and the command is there and hoe to us it but there is no blend option.... Help, thanks! Another thing but this is less of a hurry, has anyone done kwall panels before and if so is there a way to get the effect, I model the panels almost as they are with an outer frame two panels and in between the other thinner frame, but I am struggeling to get the "look" of the translucent panel. Thanks Link to comment Share on other sites More sharing options...
