jtiscareno Posted September 14, 2005 Share Posted September 14, 2005 OK guys please be gentle, no actually be honest and please tell me c&c, this is my first try with vray, had to jump to it because interior image was to heavy for viz radio and I was not getting the result I wanted with Brazil. I have been very impressed with vray and would like to learn much, much more so please any comments, crits, advice, tips, etc is greatly welcomed. I will post more wips in same thread as they are finished. Thanks to all in advance! Link to comment Share on other sites More sharing options...
martincg Posted September 14, 2005 Share Posted September 14, 2005 hi akzit, what is your settings of render /color,normal,dist threshold etc/ which version of vray is it? post screenshot of viewport where is light settings too c: - somethings is wrong with your GI setting /IR map/ - dark splotches on ceiling - bleeding colors /wrong GI settings/ - colours are too much washed out - use camera corrector - for direct light use area shadows - floor is too simple : pattern, reflections /fresnel or fall off map in reflection slot/ - frame on top is too dark - use reflections on yellow wall material - round part of ceiling looks like have not enough polygons, too sharp but for first try it is not bad Link to comment Share on other sites More sharing options...
Hao La Posted September 15, 2005 Share Posted September 15, 2005 The camera correction has problem with Vray , post you render setting and we will tell you what to do . Link to comment Share on other sites More sharing options...
martincg Posted September 15, 2005 Share Posted September 15, 2005 Hao LA: camera correction works good for me with v-ray Link to comment Share on other sites More sharing options...
jtiscareno Posted September 15, 2005 Author Share Posted September 15, 2005 OK guys thanks for all the comments, sorry forgot to post settings. Here is a reworked image and the settings. I have been following several tutorials but sometimes tips or experience is a lot better, so thanks!!! Link to comment Share on other sites More sharing options...
Tim Saunders Posted September 16, 2005 Share Posted September 16, 2005 much better. still a little blotchy. i couldn't see in your settings where the gi samples are. usually that will get rid of some of the spots. are the mullions in that skylight really black? they just seam REALLY black. even if ytheuy are stark black you should see some specular highlights. if its metal crank up the specular to 75 or more, and keep the diffuse real low (under 20). Link to comment Share on other sites More sharing options...
