Sketchrender Posted September 21, 2005 Share Posted September 21, 2005 Hi I model in formz, and file reference the dwg in. All the layers come in fine. How do i place, for example builing by building layers togther in Layer, ( or group) so as to make layering easier, and turning on and off layers easier? Is this possible ? Any advise would be welcome. phil Link to comment Share on other sites More sharing options...
mbr Posted September 21, 2005 Share Posted September 21, 2005 Max's layering system is archaic compared to any program I know of with layers. You can't have any subfolders and when you make a group, it puts the group on whatever layer is current, regardless of where the objects reside - stupid. The best method I've found is to import, then select the objects you will be turning off together and put them on a separate layer. For example, I might have layers called Trees, Furniture_Kitchen, Furniture_Living Room. I also try to put them on layers based on their materials, like Wood, Metal, Stone, etc., so that I can select everyting on that layer at once. Hope that helps. I know it's ridiculous that they can't make a better system (well, they can, as evidenced by that plugin that Jeff posted in the news - looked pretty cool). Link to comment Share on other sites More sharing options...
Chris Johnson Posted September 22, 2005 Share Posted September 22, 2005 One thing that fangorn does that the normal layer manager does NOT do is work with groups better: If you have a group who's objects span multiple layers, turning off one layer will turn off the entire group. Obviously not very fun. I made my layer manager overcome that obstacle, so when you turn a layer off and on, only the objects on that layer are turned on and off, thus groups become, 'transparent.' Chris J. Link to comment Share on other sites More sharing options...
