only3d Posted September 21, 2005 Share Posted September 21, 2005 hi 2 all and from 1 weird problem 2 a weirder one!- ive imported adt models 2 max many many times before, but out of the blue it started acting really weird and the model is constantly in wireframe mode! its not really wireframe (i tried f3 and f4 and so on..) its seems as if the model is only the contour of wat it used 2 b (well kinda like wf but not exactly the same..) even weirder still- wen i import older adt models of mine it does work! (same version and all) oh and just 2 make sure its not an ADT problem- i can still import the models 2 my good and old VIZ3.. IS THAT WEIRD OR WHAT?? please help.. its really importent ps- im using MAX7 and importing DWG files Link to comment Share on other sites More sharing options...
Brian Cassil Posted September 21, 2005 Share Posted September 21, 2005 Sounds to me like you need to install the correct Object Enabler for ADT. Check this out. www.autodesk.com/oe Link to comment Share on other sites More sharing options...
only3d Posted September 23, 2005 Author Share Posted September 23, 2005 excellent! tnk u brian, it works! Link to comment Share on other sites More sharing options...
