Not showing when renderd.
iheanyi
i'm not sure just how many parameters are available in vizrender (this is what comes with architectural desktop right?). are you seing the object itself but not with the material applied? if so, make sure you have some uvw mapping applied to the object. if your not even seeing the object check the objects propertied by right clicking. make sure visible to camera is checked. another option is on the render drop down menu right next to the reder button, make sure view is selected. these options may be particular to the full version of viz so i'm nmot sure if this even helps. good luck.
