problem with rotating objects
kris
When I use to work in Rhino it was simple to rotate objects. Lets say That I make square but not ortogonal, maybe 37 degrees towards global axis and than I want to rotate it so its ortogonal. How can I do that in Max.
In Rhino I just press mouse on one corner of a square and than on another corner and rotate it with shift or some horizontal line so I can snap on it, but in Max I can only rotate by eye.
Max has ok snap controls for moving objects but when it comes to rotation I get crazy.
Am I missing something.
There is a snap angle button on a toolbar.
In the Reference tab (right click on button) you can set your angle snap.
Maybe your rotate gismo is of --> the you need to activate it --> press X or go to gismo tab in your preference settings.
Hopefully this will fix your problem (rotating in max is easy, when you knon how).
Yes I understand that but problem is that I dont know whats the angle and I have to rotate it so it is ortogonal. The angle could be 27.736247... degrees, I mean any angle.
In rhino its very simple but in Max I am crazy and dont know how to do it precisely.
Align command doesnt work becouse I drowe this square like that on the picture with lines. I didnt use square and just rotated it to this position on the picture, so axis is aligned to the world and not to object.
The other thing you explaned I didnt quite understand, but it sounds complicated for just simple rotation of one object.
One way I can think off is to measure angle in Autocad between square and world x-axis and than write it manualy in max rotation modifier, but this is also complicated if you have tens or houndreds of objects with diferent angles.
