Lightscape/Hardware Benchmarks
I've moved this thread from the "Athlons in Production" before that thread got too big. ;)
Here is the OpenGL tester. I don't think it's been online for several years.
OpenGL Tester
Run the test and post your results here. Be sure to post all of the information that is generated, so that equal comparrisons can be made.
Make sure you run the test window at 400 x 400 and do not have anything covering the window while testing
[ May 14, 2002, 11:27 AM: Message edited by: Jeff Mottle ]
This test seems a bit...weak but I'm posting results anyway :)
Leadtek Ti 4400 running at 300/600 (Core/ram)
P4 1.8A with 1024 megs of Mushkin PC2700 DDR
Driver 28.32 (Leadtek)
Ogl version 1.31
Desktop 1280x1024x32
TeapotWire 81
TeapotFlat 71
Teapotshaded 71
DiskWire 82
DiskFlat 79
DiskShaded 77
Was running windows 98 SE...ya I know, its my play computer :).
[ May 14, 2002, 09:42 AM: Message edited by: Greg Hess ]
System #2
Windows 2000 SP2
Dual 1900+ MP with 1024 megs of PC2100 Mushkin
Quadro DCC
Driver version: 21.83
OpenGL: 1.30
Desktop: 1280x1024x32
WireTea 60
Flattea 60
Shadedtea 60
Wiredisk 60
Flatdisk 60
shadeddisk 60
Err. No matter what I did, no matter what settings I changed, the DCC ran it at 60 fps. Extremely consistently I might add. The ti 4400 jumped the fps around a bit, from 77 to 83 to 78 etc. The DCC just jumped right to 60 and stayed there.
I think we need a more stressful test. I think I heard the ti 4400 snoring while I ran it.
[ May 14, 2002, 10:41 AM: Message edited by: Greg Hess ]
ELSA Gloria II 64MB SDR
Compaq AP550 Dual PIII 733 MHz 640MB RDRAM
Driver 5.3.5.172 (ELSA)
Ogl version 1.1.4
Drawing window height 400 x 400
TeapotWire 71
TeapotFlat 45
Teapotshaded 39
DiskWire 165
DiskFlat 235
DiskShaded 92
Windows 2000 SP2
[ May 14, 2002, 11:21 AM: Message edited by: Jeff Mottle ]
Greg make sure you post the window size of the test window. I ran at 400 x 400 the default. You can push the card more by going full screen with the test window, but the problem is that the info dialog will cover the geomery and give higher than expected results.
Gainward GF4 4600, 300/650 128 ram
P III 1GHz (133 fsb) 512 MB crucial pc133 SDRAM
Win2k pro sp2
drivers 28.32 (Gainward)
ogl 1.3.1
Test1: dual/single monitors, OGL on 1 monitor (1280x1024x32 100 Hz single/double - same result):
TeapotWire 84
TeapotFlat 57
Teapotshaded 56
DiskWire 101
DiskFlat 102
DiskShaded 101
Test 2: dual monitors 1280x1024x32 100 Hz with "enable advanced multiple monitors" (results are same for both):
TeapotWire 51
TeapotFlat 50
Teapotshaded 49
DiskWire 100
DiskFlat 101
DiskShaded 100
BTW slight card overclocking doesn't make a difference, too much overclocking results in some polygons shaded incorrectly and eventual freeze - with the same framerate.
IRS sent me a request for additional documents instead of a refund - that athalon will have to wait.
[ May 14, 2002, 07:12 PM: Message edited by: dvornik ]
Jeff/Greg,
Here are mine using the reference NVIDIA Quadro2 Pro card (64Mb)
Computer:Tyan MP with AthlonMP 1600+ duals (BIOS 1.04){Home built}
OGL test size: 400x400 size using NVIDIA 28.32 (with AGP registry fix to avoid 'multipe_IRP complete_requests' BSOD's).
OGl version: 1.2
Screen res: 1280x960x32
Teapot: Wireframe: 72 fps
Flat: 64/65fps
Shaded: 58 fps
Disk: Wireframe: 72fps
Flat: 72 fps
Shaded: 72 fps
Yes full screen and 400x400 is the same. This reminds me that we can use the LS Viewer as well and use a standard .ls file and rotate around? Didn't that thing have an fps indicator as well? We need to decide on the screen size standard... :) This will probably give a better perspective or the performance of each card huh?
[ May 14, 2002, 07:57 PM: Message edited by: Arnold Gallardo ]
matrox G400
Dell dimension 4100 PIII 1000Mhz 512 RAM
Ogl version 1.1.3
Desktop 2048x768x32
TeapotWire 65
TeapotFlat 45
Teapotshaded 31
DiskWire 29
DiskFlat 36
DiskShaded 13
Windows 2000 SP2
THIS SUCKS..... :(
ELSA Gloria DCC
Siemens Celsius Dual PIII 1000 MHz
Driver 1.5.7.0 (ELSA)
Ogl version 1.2.2
Desktop 1600x1200x32
TeapotWire 64
TeapotFlat 50
Teapotshaded 50
DiskWire 63
DiskFlat 63
DiskShaded 60
Windows 2000
ELSA Gloria III
AMD Athlon XP 2000+
1.66GHZ
IWILL XP-333R rev. 2.1
768 MB of RAM (DDR PC-3000)
Ogl version 1.2.2
Desktop 1152x864
TeapotWire 80
TeapotFlat 77
Teapotshaded 77
DiskWire 78
DiskFlat 77
DiskShaded 77
Windows XP Pro :confused:
Guest adrian_dav
AMD 1800+ x2 on Tyan Tiger MP
ATI 8500 Driver Ver.: 1.3.3062
WindowsXP
window size: 400x400
Wire Tea 180
Flat Tea 115
Shaded Tea 115
Wire Disk 260
Flat Disk 404
Shaded Disk 139
GeForce Ti 4400 AGP
Dual AMD 1900+ 2 GB RAM
Driver 28.32(LeadTek)
Ogl version 1.3.1
TeapotWire 85
TeapotFlat 85
Teapotshaded 85
DiskWire 85
DiskFlat 85
DiskShaded 85
Windows 2000 SP2
Odd, no matter what I did got 85fps. :rolleyes:
[ May 15, 2002, 11:26 PM: Message edited by: Jeff Mottle ]
Guest settec+
Duron 1000@1100
Geforce2 (Sparkle) Mx400 64Mb -> "Softquadred"
640 Mb pc133
Windows 2000
1280x1024 32bit:
TeapotWire 50
TeapotFlat 30
Teapotshaded 26
DiskWire 23
DiskFlat 19
DiskShaded 13
1280x1024 16bit:
TeapotWire 74
TeapotFlat 51
Teapotshaded 46
DiskWire 86
DiskFlat 86
DiskShaded 86
Just a question... If I run the test @ 32bit color depth, oglinfo says GL_RENDERER: Generic GDI, GL_Version: 1.1.0, wether if I run the test @ 16bit it says GL_RENDERER: Quadro 2MXR/AGP/3DNOW, GL_Version: 1.3.0 ? It sounds a bit confusing...
settec+
