only3d Posted September 24, 2005 Share Posted September 24, 2005 hi all i guess i pressed something cuz everything i create is constrained automaticly 2 the xyz 0 i cant even move anything anyone knows how do i cancel it? Link to comment Share on other sites More sharing options...
ipdesigner Posted September 25, 2005 Share Posted September 25, 2005 *maybe all objects were freezed? Link to comment Share on other sites More sharing options...
ajvbochove Posted September 25, 2005 Share Posted September 25, 2005 I think: You have to reset your Controllers. Default controllers Transform Controller Position/ Rotation/ Scale Position “ Bezier Position Rotation “ TCB Rotation Scale “ Bezier Scale Make box and assign controllers. Don't forget to "make default" I had this problem once, I don't know alot of these controllers. I hope this works. Link to comment Share on other sites More sharing options...
only3d Posted September 25, 2005 Author Share Posted September 25, 2005 Tnx AJ but i didnt understand exactly wat 2 do- where do i restore the default settings? Link to comment Share on other sites More sharing options...
ipdesigner Posted September 25, 2005 Share Posted September 25, 2005 *is it about UI? *go to 'Customize' then 'Load Custom UI Scheme' then choose 'default UI'. i hope i got it right Link to comment Share on other sites More sharing options...
only3d Posted September 25, 2005 Author Share Posted September 25, 2005 i dont think its the UI cuz it was the 1st thing i tried Link to comment Share on other sites More sharing options...
Astuti Posted September 25, 2005 Share Posted September 25, 2005 As ajvbochove said, It's because of your "Position Controller". Create a box, go to the motion panel/Assign Controller, and make sure that, in Position Controller, you have "Position XYZ". If not, you'll have to "reasignate" it with the upper button. As you were said, don't forget to check "make default". Hope it helps Hope you understand my "english" Bye! Link to comment Share on other sites More sharing options...
Woody Posted September 26, 2005 Share Posted September 26, 2005 You could give this a try: In the main 3ds Max directory on your C drive you should have a file labled 3dsmax.ini cut and past this onto your desktop. When you reopen max it will create a new 3dsmax.ini file which should take max back to what it was like when you first installed it, unfortunatly you'll loose all the paths you've configered and viewport preferences, basically anything you've altered since you first installed max. Its a bit of a long winded fix but it should work, it it doesn't just delete the newly created ini and replace it with the one on your desktop. Mark. Link to comment Share on other sites More sharing options...
only3d Posted September 26, 2005 Author Share Posted September 26, 2005 woody & astuti tnx 2 both of u's both your advise was good, somehow i manged 2 forget that i changed the default constraints to path, but now i fixed it so tnx a bunch! Link to comment Share on other sites More sharing options...
