CAD to MAX
raterry
Hello All,
Quick question...I have a CAD file I'm trying to import to MAX (ver. 5.1) as a DXF. My MAX units are set to U.S. standard feet w/ fractional inches. When I import the dxf the building which is 230' wide in CAD becomes like 2750' in MAX. I can't figure out how to keep it at the right scale on import, is it a setting in CAD? I'm pretty CAD ignorant. I'd rather not scale the object in MAX to retrofit it to the size I need if I don't have to.
Thanks for any advice,
-=Rob
You need to check and make sure your "system units" is set to the same as your cad units. It probably needs to be inches and is feet. Go to customize/units setup/ and then hit the "system units setup" button. make sure you have inches selected from the drop down list. If it still doesn't scale properly, you need to find out what the system unit for the cad file is and then set it to that.
