carlangas Posted September 28, 2005 Share Posted September 28, 2005 Hi all, this morning i tried to boot up my pc, only to find that nothing apeared on screen and the num lock light was flashing. the pc was on and but nothing happened, no hard drive noise. it boots when it wants to and sometimes it even shuts down itself as it tries to boot, once it boots it seems to behave ok, i tried running a diagnostic tool from its manufacturer (compaq) and when it got to the hard drive tests it just reboot itself, I run diskscan and it gave no error messages. now its behaving ok but im afraid it will keep on doing this. have any of you had a similar problem? or know of a free diagnostics too out there. thanks Link to comment Share on other sites More sharing options...
carlangas Posted September 28, 2005 Author Share Posted September 28, 2005 yeah im running xp home sp2, the pc never gave me problems. its 3yrs old but it gets the job done. p4 2.5mhz 1g ram Link to comment Share on other sites More sharing options...
kippu Posted September 28, 2005 Share Posted September 28, 2005 sounds like overheating to me but since it works if it boots off ... must be a ram ..... do u hear any beep sounds ? Link to comment Share on other sites More sharing options...
AJLynn Posted September 28, 2005 Share Posted September 28, 2005 Also could be hard drive controller - considering it crashes on the hdd diagnostic. Link to comment Share on other sites More sharing options...
carlangas Posted September 28, 2005 Author Share Posted September 28, 2005 thanks for the responses, there is no beeping what so ever. I will look into the hard drive driver. ive had those for a year now and had not had any problems od any kind. Link to comment Share on other sites More sharing options...
radioVOY Posted September 28, 2005 Share Posted September 28, 2005 is just dust in some chips or conector, tke the memory and hard drive off and clean up the dust and then reboot, also take out the videocard and clean the fan, use compresed air to remove the excess of dust from the processors. Link to comment Share on other sites More sharing options...
carlangas Posted September 29, 2005 Author Share Posted September 29, 2005 Thanks Ever, Im going to follow your advice. Link to comment Share on other sites More sharing options...
carlangas Posted September 29, 2005 Author Share Posted September 29, 2005 Ever, I cleaned all components, disconnected the harddrive connectors, ram, cards. and havnt had any problems, ive rebooted a few times now and it seems the problem is gone, maybe something was loose.. Link to comment Share on other sites More sharing options...
