Bugga_Guy Posted September 28, 2005 Share Posted September 28, 2005 I have a file that was done by another person, who I have no contact with. Everything is fine except for one missing texture map.. I tried searching, everything! I even looking in the material editor under scene to try to find it so I can overide it with a new texture, but I can't find it.. Is there some way to find (isolate) an object that has it?, or at least in the material editor the missing texture? This is really frustraiting... any help? Link to comment Share on other sites More sharing options...
martincg Posted September 28, 2005 Share Posted September 28, 2005 hi Bugga_Guy: useful tool right side Utilities -> More -> Bitmap/Photometric Paths Info in Bitmap/Photometric Paths show objects you are talking about Max,right ? Link to comment Share on other sites More sharing options...
Msamir Posted September 28, 2005 Share Posted September 28, 2005 Thanks Martin very useful tip. Link to comment Share on other sites More sharing options...
klaas nienhuis Posted September 29, 2005 Share Posted September 29, 2005 Perhaps the texture is used as a displacement map or environment map? Klaas Link to comment Share on other sites More sharing options...
only3d Posted September 29, 2005 Share Posted September 29, 2005 sorry bugga but i dont think theres a solution 2 your problem this is like sending an autocad file without sending the xrefs & blocks linked 2 it (if ur familiar w autocad..). if i was u id look 4 a picture like it on the web its probably easier than wat u think good luck Link to comment Share on other sites More sharing options...
