Tim Saunders Posted September 28, 2005 Share Posted September 28, 2005 anyone know if vray advanced can render seperate passes for post rendered compositing? on their site in the features it says "Support for additional render elements (diffuse, reflection, GI etc)." but i don't see it in the render rolout menus images i found online. yeah they say they support additional render elements, but what does that mean? i have been using vray free and i am trying to convince the company that we need vray advanced, but lately i have really found the majic of render elements. Link to comment Share on other sites More sharing options...
martincg Posted September 28, 2005 Share Posted September 28, 2005 here is more info if you are interested in render elements in v-ray /it is only in v-ray advance/ http://www.spot3d.com/vray/help/VRayHelp150beta/examples_gbuffer.htm Link to comment Share on other sites More sharing options...
Tim Saunders Posted September 28, 2005 Author Share Posted September 28, 2005 thanks martin. that shows how render elements can ba used, however, it does not say how to do it. how would you even set it up using vray? i haven't seen any render element settings in any of the rollouts i have seen posted. Link to comment Share on other sites More sharing options...
diegofer_9 Posted September 28, 2005 Share Posted September 28, 2005 With Vray Advanced you just select the G-Buffer option and you select which channels would you like the machine to calculate. After the rendering process is done, you get the option of seeing just the reflections, just the shadows, etc. It works very similar to scanline BUT all the materials used have to be vray, or at least that's what my experience with it tells me so far. Hope this helps Link to comment Share on other sites More sharing options...
Christopher Nichols Posted September 28, 2005 Share Posted September 28, 2005 Don't forget, you also need to use the Vray frame buffer and the split G buffer under the Vray Frame buffer http://www.spot3d.com/vray/help/VRayHelp150beta/vfb_index.html Link to comment Share on other sites More sharing options...
