qwarto Posted September 30, 2005 Share Posted September 30, 2005 hi im doing some trial rendering using max 7 + vray this image is only 480 x 600 and it took 32mins maybe somebody can tell me whats wrong and there are some color bleeding as well. one directional light + vray light on the opening i attached the file and my settings Link to comment Share on other sites More sharing options...
diegofer_9 Posted September 30, 2005 Share Posted September 30, 2005 Hi, I've used vray only for a few months so I am no expert, but one thing that I do notice is that your environment is black, so that wont help a lot with the lighting of the scene, I would use either a light blue or a white color. Also, I see that your second bounce is photon map. When using photon maps the trick is to use it for both bounces and then save that map and re-use it but chenging the first bounce to irradiance. Is a little hard to explain but here is a good tutorial: http://www.evermotion.org/forum/viewtopic.php?t=1826&postdays=0&postorder=asc&start=0 However, I find that using light cache instead of photon gives you faster results. There is also a good tutorial here: http://www.spot3d.com/vray/help/VRayHelp150beta/tutorials_interior.htm Good luck Link to comment Share on other sites More sharing options...
ecastillor Posted September 30, 2005 Share Posted September 30, 2005 he is using a light blue environment in the gi Link to comment Share on other sites More sharing options...
diegofer_9 Posted September 30, 2005 Share Posted September 30, 2005 but doesnt it matter that he has a black color in the environment? I know that vray is supposed to override this, but I thought that you had to change the max environment anyway, no? I might be wrong. Link to comment Share on other sites More sharing options...
Sawyer Posted September 30, 2005 Share Posted September 30, 2005 Go to LC for second bounce and set it to like 300 see what is looks like. Photon map takes tiime. Link to comment Share on other sites More sharing options...
chodney Posted September 30, 2005 Share Posted September 30, 2005 To speed up the render..... under Irradiance Map, put the Hemispheric subdivision down. Try like 8 for test renders. Also, set the Irradiance Map preset to low for test renders Color bleed, I've just learned, can be reduced under the GI rollout. There is a saturation spinner, defaulted to 1.0. To reduce color bleed, make it 0.6 or lower. That wood floor is really saturated, I'd turn down the RGB output on the bitmap. Link to comment Share on other sites More sharing options...
qwarto Posted October 1, 2005 Author Share Posted October 1, 2005 thanks for all the help guys im posting again soon as soon as i try all this info from u guys thanks Link to comment Share on other sites More sharing options...
manta Posted October 2, 2005 Share Posted October 2, 2005 you're using 30 bounces in your photon map, maybe that is kind of excessve... Link to comment Share on other sites More sharing options...
Christopher Nichols Posted October 23, 2005 Share Posted October 23, 2005 you're using 30 bounces in your photon map, maybe that is kind of excessve... Not for photon mapping in Vray... very little difference between 5 and 30 bounces. Link to comment Share on other sites More sharing options...
