Undo Problem.. Max 7
Woody
Was wondering if any of you guys have had a problem with the undo in Max recently, as over the past week all of the copies we have in the office have started to play up, crashing machines when you click on it.
We have installed a plugin called Bionatics recently and that is the only thing that I think of which could be causing the problem?
Any ideas appreciated.
Mark - Very interesting! We've been having similar issues and have also recently started using bionatics. I hadn't previously linked the two as the crashes occur in projects which have no bionatics objects in them but I will try removing the plugin and see if that affects stability.
